CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
CFD 2019 Launch Problem
14 REPLIES 14
Message 1 of 15
5158 Views, 14 Replies
Hi everyone,
I download CFD 2019 with browser download. Run it as administrator. But it again and again given error on the splash screen.
Note: I download it with edu license but I didn't enter license information yet.
Windows 10 Pro, 8 GB DDR4 RAM, Nidia GT 1060, Intel i5 7th Gen
Hi everyone,
14 REPLIES 14
Message 2 of 15
matt.bemis
matt.bemis
@Anonymous,
Chances are it's the known issue. I posted a thread on it and pinned it to the CFD forum.
https://forums.autodesk.com/t5/cfd-forum/if-you-are-having-problems-launching-cfd-2019-with-an-edu/td-p/8009774
Matt Bemis
Technical Support Specialist
@Anonymous,
Matt Bemis
Message 3 of 15
in reply to: matt.bemis
Don’t you read my message ? I tried that way
Message 4 of 15
matt.bemis
matt.bemis
@Anonymous,
Good point. What's the error you are getting on the splash screen?
Matt Bemis
@Anonymous,
Matt Bemis
Message 5 of 15
It is an Autodesk CFD Error Report screen. Starting as “A software problem has caused Autodesk CFD to close unexpectedly.”
I can’t attach ss, on mobile.
Message 6 of 15
matt.bemis
matt.bemis
@Anonymous,
Hmmm, not sure why this would happen. Does it occur when you are opening a specific project? Or just opening the UI? What happens if you try to open Autodesk CFD without loading a project? Will that at least load?
Matt Bemis
@Anonymous,
Matt Bemis
Message 7 of 15
I attached what is happening on splash screen.
Message 8 of 15
Xiaojin.Zhang
Xiaojin.Zhang
Autodesk Support
Autodesk Support
Hello @Anonymous,
CFD 2019 supports 64-bit of windows 10. Could you please confirm if your operating system is 64 bit or 32 bit?
Please also make sure your graphic card driver is up to date.
Besides, we recommend minimum of 12 GB RAM to run CFD, did you try to install CFD on the other machines?
Thanks!
Xiaojin Zhang
Hello @Anonymous,
Thanks!
Xiaojin Zhang
Message 9 of 15
in reply to: Xiaojin.Zhang
Okay, my machine has 8 GB RAM. That is problem. Thanks.
So, how can i get CFD 2018 serial number. I couldn't find on my account. There isn't cfd motion serial.
Message 10 of 15
Hi Xiaojin,
I am sure my computers are 64-bit and  windows 10, but none of them can launch CFD 2019. I reinstalled it, still does not work. Is there any way to fix this issue? I tried to install CFD 2019 in two computers,  none of them work.
I tried to download previous version but found the only version available now is 2019 version. I can not save intervals using my 2017 version even I set it up, that's why I was thinking about download the latest version. Thanks.
Hi Xiaojin,
Message 11 of 15
I also have had issues running CFD, and have uninstalled and reinstalled several times. I've looked at several forums with no results that would work. Every time I open it straight from the app it doesn't open, and when I attempt to open it from revit with the assessment tool I get an error report message from Autodesk. Is there anything suggestions you can offer to help? error.PNG
Message 12 of 15
i have a NVIDIA GTX 960M of 12 MB.
but the
@Xiaojin.Zhang wrote:
Hello @Anonymous,
Thanks!
still doesn't start.
How omeone can help me?
but the
Hello @Anonymous,
Thanks!
Message 13 of 15
Hi!
I had same problems as mentioned above. I tried everything (clean uninstalls, running as admin, trying other computer etc.), it was frustrating.
But finally, I got the software to work by reinstalling it through manage.autodesk.com and changing the install method to "Install Now". Got CFD 2019 to launch (Revit add-in still doesn't work).
Maybe it helps someone.
(Specs: Win10, i7-7700HQ CPU, 16 GB RAM, 64-bit)
Hi!
Message 14 of 15
Hi, I´ve a Quadro P2000, a core i5 9th generation and 16 gb de ram. When I try into cfd after some seconds it closes. Only load for a few seconds and then it closes.
Message 15 of 15
Hello, Is there any explanation or workaround for CFD not being compatible with NVIDIA Quadro M2000?
