Message 1 of 12
- Mute
- Permalink
- Report
i am using CFD 2013 for thermal simulations and get a problem i can't fix.
My workflow:
Setting up a simulation with a parasolid file and configuring all parameters was not a problem.
But then the mesher occurs an invalid point for meshing in the geometry. I fixed this using a CAD program. After that i updatet the CAD in the simulation.
When i want to run the simulation again the following error occurs:
"The simulation cannot run because the design geometry is being updated."
It is also not more possible to update the geometry again. I have to set up a complete new simulation.
So, do you know a solution for this?
with kindly regards
Martin
