Boundary Conditions Setting for Natural Ventilation Model
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Dear All,
I would like to ask for your suggestion regarding natural ventilation model.
I want to simulate a natural ventilation model which combine the internal and external flow, like the one in this page https://knowledge.autodesk.com/support/cfd/learn-explore/caas/CloudHelp/cloudhelp/2014/ENU/SimCFD/fi...
I attached the png file of my model after simulating it. So basically, the model is already covered with an external void which represents the external air around the building. I set up the model as follows:
1. Material environment changed to variable and set to the actual air temperature (30 C)
2. All wall, floor, and roof set as concrete
3. There is a human model as well to analyze the thermal comfort
4. Set one surface in the external void box as inlet, and the opposite surface as outlet
5. Set the top surface of the external void box as slip/symmetry
6. Set the velocity on the other sides of the external void box (next to the top surface) to have the same direction and velocity as the inlet boundary condition (I did the set up like this because I followed this post: http://simhub.autodesk.com/discussions/threads/330/post/5547674)
And My questions are:
1. As can be seen from the attached figure, Does the external void box is still too small in this case? because the velocities in both sides of the building (colored green) are higher as if there are constrictions around that part. Does that mean the both sides of the external void box are not represent free external air?
2. And, also from the figure, it can be seen that the iteration process shows a very jagged line. Does it indicate something is wrong in my current setting?
3. I also read in this post (http://simhub.autodesk.com/discussions/threads/330/post/5547674) that I cannot apply internal boundary conditions. So, does it mean that I cannot set boundary conditions in the internal geometry, such as wall or floor or ceiling of my model? What if I need to assign temperature boundary condition in the internal wall to obtain a more accurate result, what is the best approach that I could do?
Looking forward to hearing your suggestions
Thank you
