BEX64/MSVCR110.dll crash
I seem to be having a weird problem. I have been running a simulation for a few hours and it reached iteration 242 and it then crashed with a BEX64 error, I then ran it again from iteration 200 (last save) and once again it crashed in the same place with the same error. The second time I tried running it, it crashed on iteration 221.
I have attached the error report file, the faulting module is MSVCR110.dll. I have tried repairing and reinstalling the vc 2012 files. Updated my graphics card a few days ago but ran a simulation for 2500 iterations with no problems after so I dont believe this is the problem. Any other suggestions?
Fault bucket 81694744532, type 5
Event Name: BEX64
Response: Not available
Cab Id: 0
Problem signature:
P1: SimCFDSolver.exe
P2: 15.1.2014.515
P3: 53755e40
P4: MSVCR110.dll
P5: 11.0.51106.1
P6: 5098826e
P7: 00000000000740c4
P8: c0000409
P9: 0000000000000007
P10:
Faulting application name: SimCFDSolver.exe, version: 15.1.2014.515, time stamp: 0x53755e40
Faulting module name: MSVCR110.dll, version: 11.0.51106.1, time stamp: 0x5098826e
Exception code: 0xc0000409
Fault offset: 0x00000000000740c4
Faulting process ID: 0x2770
Faulting application start time: 0x01d03d44488ad490
Faulting application path: C:\Program Files\Autodesk\Simulation CFD 2015\SimCFDSolver.exe
Faulting module path: C:\WINDOWS\SYSTEM32\MSVCR110.dll
Report ID: fa0da2c3-a93d-11e4-831f-10c37b6e883a
Faulting package full name:
Faulting package-relative application ID:
Version=1
EventType=BEX64
EventTime=130671780392089497
ReportType=2
Consent=1
UploadTime=130671780398973610
ReportIdentifier=fa0da2c4-a93d-11e4-831f-10c37b6e883a
IntegratorReportIdentifier=fa0da2c3-a93d-11e4-831f-10c37b6e883a
NsAppName=SimCFDSolver.exe
Response.BucketId=27710e693a20e90c7e509dfa3a86f944
Response.BucketTable=5
Response.LegacyBucketId=81694744532
Response.type=4
Sig[0].Name=Application Name
Sig[0].Value=SimCFDSolver.exe
Sig[1].Name=Application Version
Sig[1].Value=15.1.2014.515
Sig[2].Name=Application Timestamp
Sig[2].Value=53755e40
Sig[3].Name=Fault Module Name
Sig[3].Value=MSVCR110.dll
Sig[4].Name=Fault Module Version
Sig[4].Value=11.0.51106.1
Sig[5].Name=Fault Module Timestamp
Sig[5].Value=5098826e
Sig[6].Name=Exception Offset
Sig[6].Value=00000000000740c4
Sig[7].Name=Exception Code
Sig[7].Value=c0000409
Sig[8].Name=Exception Data
Sig[8].Value=0000000000000007
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=6.3.9600.2.0.0.768.101
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=2057
DynamicSig[22].Name=Additional Information 1
DynamicSig[22].Value=5ccd
DynamicSig[23].Name=Additional Information 2
DynamicSig[23].Value=5ccd84f1eddd293943c035be7ab0b255
DynamicSig[24].Name=Additional Information 3
DynamicSig[24].Value=7daf
DynamicSig[25].Name=Additional Information 4
DynamicSig[25].Value=7daf224bde503363175913e482049b6b
UI[2]=C:\Program Files\Autodesk\Simulation CFD 2015\SimCFDSolver.exe
UI[3]=SimCFDSolver 2015 has stopped working
UI[4]=Windows can check online for a solution to the problem.
UI[5]=Check online for a solution (recommended)
UI[6]=Check for a solution later (recommended)
UI[7]=Close
UI[8]=SimCFDSolver 2015 stopped working and was closed
UI[9]=A problem caused the application to stop working correctly. Windows will notify you if a solution is available.
UI[10]=&Close
LoadedModule[0]=C:\Program Files\Autodesk\Simulation CFD 2015\SimCFDSolver.exe
LoadedModule[1]=C:\WINDOWS\SYSTEM32\ntdll.dll
LoadedModule[2]=C:\WINDOWS\system32\KERNEL32.DLL
LoadedModule[3]=C:\WINDOWS\system32\KERNELBASE.dll
LoadedModule[4]=C:\Program Files\Autodesk\Simulation CFD 2015\QtCore_Ad_4.dll
LoadedModule[5]=C:\Program Files\Autodesk\Simulation CFD 2015\QtNetwork_Ad_4.dll
LoadedModule[6]=C:\Program Files\Autodesk\Simulation CFD 2015\QtXml_Ad_4.dll
LoadedModule[7]=C:\WINDOWS\system32\WS2_32.dll
LoadedModule[8]=C:\Program Files\Autodesk\Simulation CFD 2015\msmpi.dll
LoadedModule[9]=C:\Program Files\Autodesk\Simulation CFD 2015\tasklib.dll
LoadedModule[10]=C:\Program Files\Autodesk\Simulation CFD 2015\libsmlog.dll
LoadedModule[11]=C:\Program Files\Autodesk\Simulation CFD 2015\adlmint.dll
LoadedModule[12]=C:\WINDOWS\system32\ADVAPI32.dll
LoadedModule[13]=C:\WINDOWS\system32\SHELL32.dll
LoadedModule[14]=C:\WINDOWS\SYSTEM32\MSVCP110.dll
LoadedModule[15]=C:\WINDOWS\SYSTEM32\MSVCR110.dll
LoadedModule[16]=C:\WINDOWS\system32\USER32.dll
LoadedModule[17]=C:\WINDOWS\system32\ole32.dll
LoadedModule[18]=C:\WINDOWS\system32\NSI.dll
LoadedModule[19]=C:\WINDOWS\system32\RPCRT4.dll
LoadedModule[20]=C:\WINDOWS\SYSTEM32\MSVCR100.dll
LoadedModule[21]=C:\WINDOWS\SYSTEM32\MSWSOCK.dll
LoadedModule[22]=C:\WINDOWS\SYSTEM32\Secur32.dll
LoadedModule[23]=C:\Program Files\Autodesk\Simulation CFD 2015\tbb.dll
LoadedModule[24]=C:\WINDOWS\SYSTEM32\VERSION.dll
LoadedModule[25]=C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.9600.16384_none_34a8918f959016ea\COMCTL32.dll
LoadedModule[26]=C:\WINDOWS\system32\COMDLG32.dll
LoadedModule[27]=C:\WINDOWS\SYSTEM32\NETAPI32.dll
LoadedModule[28]=C:\WINDOWS\SYSTEM32\WSOCK32.dll
LoadedModule[29]=C:\WINDOWS\system32\OLEAUT32.dll
LoadedModule[30]=C:\WINDOWS\system32\msvcrt.dll
LoadedModule[31]=C:\WINDOWS\SYSTEM32\sechost.dll
LoadedModule[32]=C:\WINDOWS\SYSTEM32\combase.dll
LoadedModule[33]=C:\WINDOWS\system32\SHLWAPI.dll
LoadedModule[34]=C:\WINDOWS\system32\GDI32.dll
LoadedModule[35]=C:\WINDOWS\SYSTEM32\netutils.dll
LoadedModule[36]=C:\WINDOWS\SYSTEM32\srvcli.dll
LoadedModule[37]=C:\WINDOWS\SYSTEM32\wkscli.dll
LoadedModule[38]=C:\WINDOWS\SYSTEM32\SSPICLI.DLL
LoadedModule[39]=C:\WINDOWS\SYSTEM32\SHCORE.DLL
LoadedModule[40]=C:\Program Files (x86)\AVG\AVG2015\avghooka.dll
LoadedModule[41]=C:\WINDOWS\system32\winmm.dll
LoadedModule[42]=C:\WINDOWS\SYSTEM32\WINMMBASE.dll
LoadedModule[43]=C:\WINDOWS\SYSTEM32\cfgmgr32.dll
LoadedModule[44]=C:\WINDOWS\SYSTEM32\DEVOBJ.dll
LoadedModule[45]=C:\WINDOWS\system32\napinsp.dll
LoadedModule[46]=C:\WINDOWS\system32\pnrpnsp.dll
LoadedModule[47]=C:\WINDOWS\system32\NLAapi.dll
LoadedModule[48]=C:\WINDOWS\SYSTEM32\DNSAPI.dll
LoadedModule[49]=C:\WINDOWS\System32\winrnr.dll
LoadedModule[50]=C:\Program Files\Bonjour\mdnsNSP.dll
LoadedModule[51]=C:\WINDOWS\SYSTEM32\Iphlpapi.DLL
LoadedModule[52]=C:\WINDOWS\SYSTEM32\WINNSI.DLL
LoadedModule[53]=C:\WINDOWS\system32\msv1_0.DLL
LoadedModule[54]=C:\WINDOWS\SYSTEM32\cryptdll.dll
LoadedModule[55]=C:\WINDOWS\System32\fwpuclnt.dll
LoadedModule[56]=C:\Windows\System32\rasadhlp.dll
LoadedModule[57]=C:\Program Files\Autodesk\Simulation CFD 2015\tbbmalloc.dll
State[0].Key=Transport.DoneStage1
State[0].Value=1
FriendlyEventName=Stopped working
ConsentKey=BEX64
AppName=SimCFDSolver 2015
AppPath=C:\Program Files\Autodesk\Simulation CFD 2015\SimCFDSolver.exe
NsPartner=windows
NsGroup=windows8
ApplicationIdentity=D042C8047F86C906436F5A113F9BC974
