Hi Fred, thanks for your quick reply. Could I ask what do you mean by surface wrapped? Thanks a lot!!
The log:
Mesher process started...
Loading model...
Defining entity constraints...
Nodal and facet constraints complete.
Discrete model object containing 8203 nodes and 16378 facets successfully restored.
Generating surface mesh for 12 of 12 model surfaces.
Mesh size range: 1.31163 to 40.
Surface meshing completed.
Importing surface mesh...
There were 12 surfaces specified at import.
There were 1 parts specified at import.
Imported model composed of 51949 nodes and 103870 facets.
Import time: 0.84 seconds.
Manifold test:
Isolated facet count: 0.
Indeterminant facet edges: 0.
There were 0 nodes defining the trimming loop(s).
Non-manifold facet count: 0.
Manifold check time: 0.653 seconds.
Imported model is well-connected.
Imported model contains 7 unique volumes.
Loading mesh sizes and constraints...
Instituting mesh sizes...
Mesh sizes set.
Instituting boundary layer mesh sizes...
Boundary layer mesh sizes set.
Generating volume mesh...
Volume meshing complete.
Node count: 242344.
Element count: 1362567.
Mesh contains 242344 nodes and 1362567 elements.
Performing mesh quality check...
Updating model database...
Model database updated.
Updating mesh database...
Mesh database updated.
Building solver model file...
Solver file written.
