Autodesk CFD Ultimate error message (URGENT)
Message 1 of 21
Hi guys, I was running a wind CFD simulation model but have encountered the error message (see attachment). I have tried several times to re-run the model, repaired and re-installed the CFD software but the error message still persists. Could anyone help with this? It's in urgency!!! Many thanks.
Replies (20)
Message 2 of 21
Just to add on, this message popped up when I was generating the mesh and when it reached to
"Solver file written", this error message popped up.
Message 3 of 21
frederic.gaillard.7
What is your message in the logs file ?? (.txt)
Your model seems to be surface wrapped.
Fred
Message 4 of 21
Hi Fred, thanks for your quick reply. Could I ask what do you mean by surface wrapped? Thanks a lot!!
The log:
Mesher process started...
Loading model...
Defining entity constraints...
Nodal and facet constraints complete.
Discrete model object containing 8203 nodes and 16378 facets successfully restored.
Generating surface mesh for 12 of 12 model surfaces.
Mesh size range: 1.31163 to 40.
Surface meshing completed.
Importing surface mesh...
There were 12 surfaces specified at import.
There were 1 parts specified at import.
Imported model composed of 51949 nodes and 103870 facets.
Import time: 0.84 seconds.
Manifold test:
Isolated facet count: 0.
Indeterminant facet edges: 0.
There were 0 nodes defining the trimming loop(s).
Non-manifold facet count: 0.
Manifold check time: 0.653 seconds.
Imported model is well-connected.
Imported model contains 7 unique volumes.
Loading mesh sizes and constraints...
Instituting mesh sizes...
Mesh sizes set.
Instituting boundary layer mesh sizes...
Boundary layer mesh sizes set.
Generating volume mesh...
Volume meshing complete.
Node count: 242344.
Element count: 1362567.
Mesh contains 242344 nodes and 1362567 elements.
Performing mesh quality check...
Updating model database...
Model database updated.
Updating mesh database...
Mesh database updated.
Building solver model file...
Solver file written.
Message 5 of 21
frederic.gaillard.7
an you send me the txt file instead ?
Thx
Fred
Message 6 of 21
Yup just sent it to you!!
Message 7 of 21
frederic.gaillard.7
i'm reffering to the CFD.log file located on your directory of your scenario. It should like this :
[15:41:10] CFD (FYP)/Design 1/Scenario 2 mesher finished at Tue Oct 6 19:29:24 2020 on CLOUD with code = 0
[15:41:14] Mesher File Size = 143.29 MB (34.98 MB compressed)
[15:41:14] Analysis::importMesherFiles = 4.411 sec
[15:41:27] CADModel::loadGeometryDatabase = 12.115 sec
[15:41:27] Mesher finished copying files
[15:41:27] CFD (FYP)/Design 1/Scenario 2 solver started at Tue Oct 6 19:29:25 2020 on CLOUD
[15:41:27] Solver Results File Size = 71.81 MB (0.02 MB compressed)
[15:41:27] Analysis::importSolverResultsFiles = 0.43 sec
[15:41:27] getJobUpdate start
[15:41:32] VizDataInterface::getBoundaryFEData = 2.199 sec
[15:41:32] VizDataInterface::setupWallOutlineData = 0.198 sec
[15:41:39] VizDataInterface::getBoundaryFEData = 2.476 sec
[15:41:39] VizDataInterface::setupWallOutlineData = 0.203 sec
[15:41:42] getJobUpdate finished
[15:45:03] CADModel::loadGeometryDatabase = 9.75 sec
[15:45:08] VizDataInterface::getBoundaryFEData = 2.636 sec
[15:45:08] VizDataInterface::setupWallOutlineData = 0.233 sec
[15:45:14] CFD (FYP)/Design 1/Scenario 1 job finished at Tue Oct 6 15:45:14 2020 on CLOUD
[15:45:38] CADModel::loadGeometryDatabase = 11.924 sec
[15:45:43] VizDataInterface::getBoundaryFEData = 2.479 sec
[15:45:43] VizDataInterface::setupWallOutlineData = 0.208 sec
[15:46:16] CFD (FYP)/Design 1/Scenario 2 mesher finished at Tue Oct 6 19:29:24 2020 on CLOUD with code = 0
[15:46:21] Mesher File Size = 143.29 MB (34.98 MB compressed)
Message 8 of 21
Sorry Fred, may I ask where can I extract the log file you were referring to? I am a newbie of CFD
Message 9 of 21
May I ask if it's in one of these files? as I tried to look for the log which has a timeline in the txt but there isn't
Message 10 of 21
frederic.gaillard.7
i should be on the log file :
Fred
Message 11 of 21
Under my log file, I only have one file called "CFD job manager". I uploaded it
Message 12 of 21
Hi Fred, just uploaded the cfz file here. Really appreciate your help:)
Message 13 of 21
frederic.gaillard.7
Hello @Anonymous ,
Can you send it through a compressed folder ?
Thx
Fred
Message 14 of 21
Hi Fred, it's already a compressed file RAR
Message 15 of 21
I just uploaded everything in rar format
Message 16 of 21
marwan_azzam
Your model runs just fine here on my end.
Please see image below.
1- Which version of CFD are you using?  Do a Help: About to find out.
2- Also, is the model saved on the local hard drive or across the network?  Make sure it is on the local drive.  Saving on network drive can cause issues.
3- Open Windows Task Manager and make sure CFDServer.exe is running under the Details tab as well as SimJobManager.exe and dssp_jobserver.exe.
4- You don't need the zero velocity BC at the bottom surface.  No boundary condition means zero velocity (non-slip).
cheers,
Marwan Azzam
Message 17 of 21
Hi Marwan, I am currently using the Autodesk CFD Ultimate 2019 and it's saved in a local drive. For part 3, do you mean I need to check it when running the model? Thanks a lot.
Message 18 of 21
marwan_azzam
Is it 2019.0, 2019.1 or 2019.2?
For #3 you can check with or without the model running.  These should be running in the background.
Marwan
Message 19 of 21
I am actually using surface book 2, not sure if it affects the modelling but three of the exe are working well when running the model... the issue still persists
Message 20 of 21
marwan_azzam
Now that we determined that the antivirus was causing the issue and turning it off caused the analysis to run, I suggest setting the exceptions detailed in this article.
Even though the article is about remote solving the exceptions still stand for local solving.
Marwan
