assign two boundary conditions for an inlet
modess.seyednezhad
Message 1 of 21
modess.seyednezhad
I am trying to define velocity and temperature for the inlet, but for some reason, I am only able to define one of them at a time. Any suggestion?
Replies (20)
Message 2 of 21
karol.suchon
Every BC are applied separately. So if you have a velocity, click on the surface, edit and change the boundary condition to temperature pressure etc. The software keeps the previous Boundary condition to the moment when you do not remove it.
BR
Karol
Message 3 of 21
modess.seyednezhad
Thank you, Karol!
I could successfully apply both Velocity and Temperature BC to the inlets, but for some reason, I cannot see any changes to the fluid!
It seems that the BC is only applied to the surface, not to the volume!
Message 4 of 21
karol.suchon
please check if you enable the heat transfer in the solver bar. Solve->Physics, if you have natural convection also do not forget about the gravity vector and setting the material as a variable, to detect the density changes.
BR
Karol
Message 5 of 21
modess.seyednezhad
I enabled that. It is forced convection.
Message 6 of 21
modess.seyednezhad
How can I set the material as a variable?
Message 7 of 21
karol.suchon
If you have auto-forced convection you should not set material as a variable, you do not want to compute the density change on the velocity field.
You could set the variable by clicking on RMC on the material and selecting edit material environment reference, there you could set it as a variable.
AutoForced convection first computes the velocity and pressure field, and later computes the temperature distribution. There is a chance that the second step was not computed yet.
BR
Karol
Message 8 of 21
modess.seyednezhad
Each inlet in this model has velocity normal, volume flow rate, and temperature as the boundary conditions.
The outlet has a pressure of zero and all walls have a heat flux of zero which represents insulation BC.
In steady state conditions, I still see no changes in temperature along the channel!!
Message 9 of 21
modess.seyednezhad
Do I need to define unknown BC for the outlet?
Message 10 of 21
karol.suchon
You could attach the zip file of the simulation.
But from the description of the boundary condition, you could only have two solutions constant fluid(equal to BC temperature and solid temperature( solid probably 0, or constant temperature in the entire geometry equal to BC, depending on where you applied 0 heat flux.
BR
Karol
Message 11 of 21
modess.seyednezhad
Here is the zip file. Could you please see where the problem is?
Thank you,
Message 12 of 21
karol.suchon
No, absolutely do not apply an unknown BC.
That is the special BC applied only for internal compressible flow.
Send me the model and I will check it, but if that is your first attempt at CFD simulation, I will strongly recommend starting from the tutorial, and a few exercises and you could work with the software without frustration.
BR
Karol
Message 13 of 21
karol.suchon
Please use that method to share the file with me.
Message 14 of 21
modess.seyednezhad
Yes, this is my first time working with Autodesk CFD. Unfortunately, the tutorials were not useful for me.
Please see the attached file.
Message 15 of 21
karol.suchon
Ok, I am not sure but probably you stopped the simulation during the first stage of auto-forced convection manually.
As I mentioned earlier, the first stage of auto-forced convection does not compute heat transfer. That is the reason why the simulation has a constant temperature. Also, the condition of the outlet walls is not necessary, by default the wall is adiabatic.
I attached the simulation with and without auto-forced convection and for both scenarios, we get the temperature gradient.
BR
Karol
Message 16 of 21
modess.seyednezhad
Dear Karol,
Thank you for assisting me.
May I know what did you change except the auto-forced convection in the result dialog box?
Did you change the boundary conditions?
Message 17 of 21
karol.suchon
The Autoforced convection works in the third scenario also. I deleted the heat flux boundary condition, on the outside wall he is applied by defoult.
BR
Karol
Message 18 of 21
modess.seyednezhad
I appreciate it!
Message 19 of 21
karol.suchon
If you do not have other questions you could accept the solution 🙂
It always better if the thread has the green accept sign 🙂
Message 20 of 21
modess.seyednezhad
I have another question. I increased the thermal conductivity and I expect to have a higher temperature drop but it was vice versa. I am not sure what is not working and I do not know how to debug it.
