Assertion Failed - Rendering
Message 1 of 10
Ran into a really weird one today. An assertion failed error. See below:
It seems to be referring to an absolute file path that includes a personal folder of someone called Jenkins? hahaha. I think someone made a programming mistake there.
This error occurred when viewing a model in Autodesk CFD 2018. The zoom function using the mousewheel stopped working, so I attempted to use the manual zoom tool and then the error immediately occurs.
Anyone at Autodesk who can help with this one?
Matthew Gent
Replies (9)
Message 2 of 10
Amal.C
Hi Matt,
Nice joke 😄 😄 !
Does this error message happen for all the models you open in CFD 2018? Did you make sure to install Update 1 of CFD 2018?
What about your graphic card? Do you have the latest driver installed on your machine?
Amal
Amal Cheikh rouhou
Message 3 of 10
I have not! I've just seen it in my autodesk desktop app. I'll install that and see whether the issue occurs again.
Message 4 of 10
Jon.Wilde
Check this out too.
In the meantime, I will go have a word with Jenkins...
Message 5 of 10
Amal.C
Hi Matt,
It would be great if you can provide us with an update regarding this issue 🙂 were you able to avoid it after installing the latest update of CFD 2018?
Amal
Amal Cheikh rouhou
Message 6 of 10
Hi Amal. Unfortunately, I cannot install the service pack with my current license. My boss has to do that and he still hasn't got round to it. So I can't say whether this will work or not yet!
I know you support guys will be eager to tick this problem off the list! You may if you want. I can always re-open another if it doesn't work.
Message 7 of 10
Jon.Wilde
Hi Matt,
Jenkins was wondering if you had a chance to apply those flags I shared above to the global settings 😉
Message 8 of 10
I'm not sure if this was ever resolved, but I have had a very similar problem. In my case, the problem was linked to the fact that I had spherical geometry in my model. I had a Brass cube (hear sink), a flattened cube rectangle for a peltier module, and a hemisphere solid (steel) on the cold surface of the peltier. It gave me this "Assertion Error" written by this jerk Jenkins multiple times. When I remodeled a hexagonal nut to replace the dome: problem solved.
I have had this same problem with FUSION 360 as well.
I even retried my hemispherical system after a succesful run on the nut. Jenkins struck again.
Message 9 of 10
jeffguida
I'm getting a similar error every time I try to run In-Canvas rendering.  Strangely this only started AFTER I upgraded my machine to a top-line Nvidia P5000 system (and graphics drivers are up-to-date).  Ironic.
Autodesk support please help!  Error below and submitted several times.
Message 10 of 10
Melissa_Wang23
Community Visitor
Community Visitor
I get this similar message when trying to click on "select all" of the wall calculator.... although it's a guy named agent. I disenabled wall layers in the meshing process, would that have anything to do with it? Please help, it's rather urgent.
