Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Are the wall layers generated on both sides of a surface part?
In my one case, the wall layer of a surface part is generated on the one side, but not on the other side like a figure.
Is it possible to have wall layers on both sides?
If it's not possible, I'll use volumes as an alternative to surface parts.
marwan_azzam
Yes, it is possible.
The fluid on either side of the surface part have to belong to two separate bodies.
I suspect in your model it is the same body (or part) on both sides of the surface part.  If you separate them into two different bodies you will get a boundary layer on both sides of the surface.
cheers,
Marwan
Hello Marwan,
I succeeded in making wall layers on both sides.
I didn't realize your idea. Thanks a lot!
Keisuke
