Are the wall layers generated on both sides of a surface part?
In my one case, the wall layer of a surface part is generated on the one side, but not on the other side like a figure.
Is it possible to have wall layers on both sides?
If it's not possible, I'll use volumes as an alternative to surface parts.
marwan_azzam
Yes, it is possible.
The fluid on either side of the surface part have to belong to two separate bodies.
I suspect in your model it is the same body (or part) on both sides of the surface part.  If you separate them into two different bodies you will get a boundary layer on both sides of the surface.
cheers,
Marwan
Hello Marwan,
I succeeded in making wall layers on both sides.
I didn't realize your idea. Thanks a lot!
Keisuke
