About Thermal Contact Resistance
What is the default thermal contact resistance between two aluminum plates when I don't assign any surface material between them? Does autodesk CFD regards these two plates as one big plates?
benoit.neu-faber
Hi @Anonymous
By defalut there is no contact resistance between two solids in CFD.
You will have to define with a surface material.
Hope this help.
Please accept solution and give likes if applicable
Benoit Neu-Faber
INNOSIM https://servicesmarketplace.autodesk.com/provider/public/innosim
Autodesk Service Provider / CFD Trainer
https://www.linkedin.com/in/benoit-neu-faber/
Hi Benoit,
Thanks for the answer. The "surface material" you mentioned is to assign "contact resistance" material to a surface, right?
As below tutorial shows:
https://help.autodesk.com/view/SCDSE/2019/ENU/?guid=GUID-FA1F07E4-579C-4F52-882D-79183766AEF1
benoit.neu-faber
Hi @Anonymous
Yes this is right
Benoit
