Salut @Anonymous,
Voici la réponse à un problème similaire mais sur la version Anglaise du forum, je vais donc en faire une petite trad rapido,
Your installation is failing due to the method (web installer) you're using. This method is unreliable and shouldn't be used.
UNE MAUVAISE METHODE DINSTALLATION EXPLIQUE L'ERREUR
Download and install per:
VOICI UNE DEMARCHE ALTERNATIVE
1. Access the Autodesk Virtual Agent and follow the download links to your product.
CLIQUE SU RLE LIEN POUR ACCEDER A LA METHODE DINSTALLATION PAR TELECHARGEMENT
http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
TELECHARGE TOUTES LES "parts" DE TA VERSION REVIT
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
OUVRE LE FICHIER part _001_00X.sfx.exe OU LE FICHIER UNIQUE
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
IL VA EXTRAIRE LES FICHIERS D'INSTALLATION
5. Once the extraction is finished, the installation will automatically start.
UNE FOIS L EXTRACTION TERMINEE L INSTALLATION VA DEMARRER
6. Follow the installation steps for your product
INSTALLE NORMALEMENT
Voila qui va résoudre ton soucis j'espère!
Tiens-moi au courant,
François
Francois-Gabriel Perraudin
BIM management and coaching
