BIM 360 Team Forum
Welcome to Autodesk’s BIM 360 Team Forums. Share your knowledge, ask questions, and explore popular BIM 360 Team topics.
On New ACC platform, is there a way to view Projects a Team Member is on?
5 REPLIES 5
nharburger
2340 Views, 5 Replies
nharburger
On the old BIM360 platform, i could go to Account Administration, look up members, find a particular member, and see what projects they had access to... When I follow those same steps on the ACC platform, I cannot seem to find a way to view what projects the team member has access to... is this functionality found elsewhere on the site, or did they remove this functionality form the ACC platform?
5 REPLIES 5
panizBMS2M
in reply to: nharburger
panizBMS2M
That is still possible to view this. Please go to "Account Admin", then hit "Members", select the member you want, and  and press Projects, then you can view a list of all projects that he has access to.
If that answers your question please choose it as solution, then others can find the answer to this question easier.
RDAOU
in reply to: panizBMS2M
RDAOU
That is no longer applicable following to the Maintenance carried out in March 2023.
The new ACC platform does not give access to the old Projects Tab for Members. The Tab listing the Projects a user a member of (accessible from the old Platform - BIM 360)  does not list the Projects which were created/hosted on new Docs platform (ACC)
Issue has been reported but no solution so far
jagostinho74
jagostinho74
this does not seem to work with projects using the ACC framework.
Is there a way of retrieving this information?
Thank you
Assistant BIM/CAD Manager
Manchester, UK
Thank you
Manchester, UK
RDAOU
in reply to: jagostinho74
RDAOU
Only using power BI and adding to dashboard. (For the time being at least)
colinSRA
colinSRA
It sure would be nice to have this basic functionality back...
