BIM 360 Team Forum
Welcome to Autodesk’s BIM 360 Team Forums. Share your knowledge, ask questions, and explore popular BIM 360 Team topics.
Free Autodesk Courses to strengthen skills in BIM ✏️
1 REPLY 1
daniel.Alvarado.cortes
470 Views, 1 Reply
Hi BIM Community!
BIM 360 Design is an efficient way to share your design with the entire team. In this unit, you learn how to upload your model to BIM 360 to monitor changes to elements in a multi-discipline project in the cloud and identify potential issues.
https://customersuccess.autodesk.com/connected-learning/course?id=280
Stay up to date in the office and on the project job site, using cloud connected data and systems. This will help you unlock capabilities to share and collaborate across the project lifecycle in real time without barriers. As a BIM manager, it is important to set up the BIM 360 project right the first time. In this unit, learn how to setup a BIM 360 project and invite people to the project for better team collaboration across disciplines and firms.
https://customersuccess.autodesk.com/connected-learning/course?id=322
Sharing design models between the architect and civil engineer helps reduce rework and improves collaboration. Use BIM 360 to share surface data after setting the geospacial coordinates for the project.https://customersuccess.autodesk.com/connected-learning/course?id=376
Coordinating infrastructure projects in the cloud helps reduce error and rework. In this course, learn how to upload your design into BIM 360. Then use markup tools to communicate required design changes. https://customersuccess.autodesk.com/connected-learning/course?id=378
Migrating Civil 3D files into BIM360 makes external references and data references available for everyone to use in the cloud. Learn how to upload Civil 3D drawing files and sheet set files for better collaboration across the team. https://customersuccess.autodesk.com/connected-learning/course?id=379
The BIM 360 App for mobile devices provides this functionality, giving the field personals the tools required to convey the site information back to the office and design teams. In this course, you learn how to download and install the BIM 360 app on a tablet device.
https://customersuccess.autodesk.com/course?id=504
The focus of this course is for you to access the project on the mobile device, you then add markups based on the site information to the BIM data. You also create issues and notify the relevant team member of any disparity onsite. https://customersuccess.autodesk.com/course?id=509
Welcome to RFI and Checklist Management using the BIM 360 Mobile App. For the BIM 360 Build Subscribers, the BIM 360 mobile app provides a number of additional functionalities. You create RFIs in the field using the specialized RFI tools. You then run various checklists, such as QA, Safety, Commissioning, and so on. Finally, for the non-compliant items, you can create issues straight from the Checklist and then manage them like normal issues.  https://customersuccess.autodesk.com/course?id=511
All the best,
Daniel
1 REPLY 1
Thank for the collection of great learning links
BIMologist / Dr. Revit
Approved Autodesk Services Marketplace provider - BIM Consulting
If you find this reply helpful, please use the Accept Solution or Like button below
