Having a problem uninstalling Autodesk Desktop Connector v12.4 from one PC. Half-way through the uninstall it pops up an error --
Error getting file security:
C:\ProgramData\Autodesk\CDX\WD\...\SymLinks\BIM 360-workspace\...\...
GetLastError:123
I have bleeped out part of the path name here. But on the PC, when I tried to access the full path listed in the error message, Windows tells me the path is too long (over 260 characters).
How can I work around these two problems? Can I just manually delete that folder? I'm guessing it's BIM 360 cache data?
Solved by smithmat. Go to Solution.
That directory is a temporary "working directory" used for Desktop Connector. With Desktop Connector not running it is safe to delete the C:\ProgramData\Autodesk\CDX\WD\ directory. Once that is finished, retry the uninstall.
I have gotten this error on 2 seperate occassions after Desktop Connector was crashing my Windows Explorer
