BIM 360 Team Forum
Welcome to Autodesk’s BIM 360 Team Forums. Share your knowledge, ask questions, and explore popular BIM 360 Team topics.
Desktop Connector - Default Column Display, Backup Files, and Notifications
0 REPLIES 0
Message 1 of 1
amadorjL8UU7
258 Views, 0 Replies
Version 15.0.0.1540
1.  We really need the ability to have "date modified in Autodesk Docs" turned on in windows by default for all of our projects. Normal windows explore setting are not applied to ADD drive, and this information is critical for our users. In the latest build, we have been seeing this column getting turned off after refreshing the view as well. I think something along the lines of "windows columns settings" is critical, so that we can control the columns visible when browsing thru projects. Attached is a screen shot of the "global settings" for reference.
2. Revit Backup Files are out of control. We are getting dozens of backup files being written to the ADD projects which are compounding the sync process. Even when Maximum Backups are set to 1 in Revit, ADD appears to ignore that and writes new backups for every save. The result is a very messy project directory, with looooong sync times, and since the users cannot see date modified in ADD by default it becomes confusing.
3. An alert that another user has the project open in Revit. We currently lock files when in use, but users do forget to lock them which has led to cross-contamination of files. When revit files are stored on a network server, it will alert the user that it is in use by another user... but not in ADD.
Labels (1)
0 REPLIES 0
