This might sound like a really dumb question, but where do you view past Daily Logs?
Solved by Shirin.arnold. Go to Solution.
Hi @Chad-Smith,
It is actually a great question. You can simply select the calendar date picker and go to past entries to view dates in the past.
Here is a link which may be of use: https://help.autodesk.com/view/BIM360D/ENU/?guid=GUID-CDBFE508-C833-42AB-9A36-A67999BBE58E
Updated url: https://help.autodesk.com/view/BIM360D/ENU/?guid=GUID-CDBFE508-C833-42AB-9A36-A67999BBE58E
Kind regards,
Shirin Arnold
Thank you. I think what threw me was I was expecting the calendar to highlight the days which had logs.
Hi @Chad-Smith,
It does on mobile and we will be adding this to web.
Shirin
Is there a way to export the information gathered in the Daily Logs? Exporting to pdf alone would be sufficient but it would be ideal if you could include issue and checklist information with daily log info. I understand that the reporting features are currently being upgraded to include multiple issue pdf reports, could daily log information like weather be part of this pdf reporting feature?
Hi @nikolas.baum ,
Yes, this is something we will be adding as functionality to the Daily Logs.
Kind regards,
Shirin
Hi @Anonymous ,
Thanks for bringing this to my attention, I have updated the link above.
Here is the new link: https://help.autodesk.com/view/BIM360D/ENU/?guid=GUID-CDBFE508-C833-42AB-9A36-A67999BBE58E
Kind regards,
Shirin
When is this expected to be released?
Also, on another thread months back, it was mentioned that customization of daily logs was on the road map as well. The ability to add fields, have drop down menus etc, would be extremely useful. When is this expected to be released?
Lastly, will insight have the ability to display metrics from daily reports? Graphs of manpower throughout the job, total hours per company etc?
Hi @RyanWalsh8255 ,
We are currently working on the copy from previous functionality.
I definitely see the value of adding insight from the dailies into the Project Home or Insight part of BIM 360 and will make sure to let the team know to consider this.
The other items are still on the roadmap.
Kind regards,
Shirin
Hi @Anonymous ,
We are working on this at the moment.
Kind regards,
Shirin
Hi, hope i'm not to late. But an export to excel/csv would be appreciated! I would love to have an overview of alle the labor hours that are logged.
Exactly my question. . . Where can you see the aggregated hours and staffing for each sub contractor?
Oh no. . . this doesn't sound good
@Shirin.arnold is this coming soon? Procore handles this really well, can the team just copy them instead of spending time considering?
Any update on when this will be released? It is a huge hole in the BIM360 functionality at the moment.
