Still trudging through the supported functions.
Where is the web based viewer. I discovered the only way I can drag/drop files is through the BIM360 Glue desktop app.
When I upload a .rvt file in this manner it cant be viewed!? Only downloaded?! This doesn't make sense. Where is the functionality of BIM 360 Team? I need simple repository for storing files for file versioning comparisons.
Unless I'm missing something (and its possible that I am) this generation is a big step backwards.
Ok it turns out a trial account of BIM360 glue is indeed the problem. BIM 360 is using that as the default account thus blocking additional services from showing up. Swapping to my actual account grants me access to the "Document Management" service. This is where I can setup the projects and simply drag and drop .rvt files in a viewable environment! Hooray!
