Version issue in BIM 360
Bnilath
Bnilath
Currently we have two deciding factors (Number & Title) for versioning in BIM 360. Please find the below case and advise.
Below drawings I uploaded in BIM 360 as V1
  • GF-STR SPD-0023 GROUND FLOOR STRUCTURAL GENERAL ARRANGEMENT PLAN ZONE-23
  • GE-STR-SPD-0231 GROUND FLOOR SECTION DETAILS ZONE-23 (SHEET 01 OF 01)
We received the commented sheet & uploaded the same as V2. We incorporated the changes & need to submit the drawings as rev 01
  • GE-STR-SPD-0231 GROUND FLOOR SECTION DETAILS ZONE-23 (SHEET 01 OF 02)
  • GE-STR-SPD-0232 GROUND FLOOR SECTION DETAILS ZONE-23 (SHEET 02 OF 02)
If I upload “GE-STR-SPD-0231” it will come as a new version (V1) because of title change. But I need this as V3 as shown below.
  • GE-STR-SPD-0231 GROUND FLOOR SECTION DETAILS ZONE-23 (SHEET 01 OF 01) (V1- Rev 00)
  • GE-STR-SPD-0231 GROUND FLOOR SECTION DETAILS ZONE-23 (SHEET 01 OF 01) (V2- Rev 00 Commented)
  • GE-STR-SPD-0231 GROUND FLOOR SECTION DETAILS ZONE-23 (SHEET 01 OF 02) (V3- Rev 01)
Thanks & Regards,
Bujair
Replies (7)
leslie.han
Hi @Bnilath,
Thanks for sharing the case with us. I wonder whether you could share the documents you mentioned above with me by private message, so that I could check it for you. And by the way, may I know whether you did this case in Plans?
Leslie Han
BIM360Docs Team
Bnilath
Hi Leslie
Files shared by private message.
Yes. The files are under Plan.
Thanks & Regards,
Bujair
leslie.han
Hi Bujair,
Currently in Docs,  we version up file only when both the number and title are the same in Plans. I saw in your case, when you upload for the third time, the title changed to "GE-STR-SPD-0231 GROUND FLOOR SECTION DETAILS ZONE-23 (SHEET 01 OF 02) " from "GE-STR-SPD-0231 GROUND FLOOR SECTION DETAILS ZONE-23 (SHEET 01 OF 01)", so it will not version up, it goes to a new V1 instead.
If you would like to make it version up as V3, please keep the title the same one.
Hope this will help.Thanks.
Best regards/Leslie Han
BIM360 Docs Team
Bnilath
Hi Leslie,
Sorry. This will not help us. This I already specified in my question (If I upload “GE-STR-SPD-0231” it will come as a new version (V1) because of title change. But I need this as V3 as shown below. ). we can’t predict the number of  section sheet at the time of rev 00 submission. Depends on the requirements it may change.
We have two suggestion
  • Change/limit the deciding factor to number
  • Give power to admin to update the title field. So we can change and update (Currently we can edit the title field after upload, but it will not change in data base. So the status will same)
Thanks & Regards,
Bujair
leslie.han
Hi Bujair,
Thanks for your reply. Totally understood your needs. For your kindly suggestions:
1) we now have the plan to do the investigation for only use "Number" as the deciding factor
2) for the second one, I strongly recommend you to post it in our Idea station so that our product team can check it.
BIM 360 Docs team
leslie.han
Hi Bujair,
A follow-up for the second point, one suggested solution:
In extraction phase, you can change the number or title to what you needs, then continue to publish them, the file will be handled by the number or title you changed.
Please refer the sceenshot below.
Hope this can be helpful.
BIM360 Docs team
Bnilath
Hi Leslie ,
Thank you for your replay.
We have more than 100 drawings (minimum )/day to upload. Sometime we are uploading more than 500. So it is very hard to go and check each title. Our drawing number will remains same. That is the reason we are requested to limit the deciding factor to number only. Anyway I will post this in Ideas.
Thanks & Regards,
Bujair
Type a product name
