Show only
Search instead for
When working on BIM 360 through Civil 3D 2021, we are having an issues in multiple drawing with editing pipe networks. After opening a file containing the network to edit, the right-click Edit Pipe Network function doesn't work. It gives you the pickbox to select the network to edit, but after selecting the pipe, it just quits the command. We found that if we run an Audit, that the functionality comes back, even though there are no errors listed in the Audit. Once you save/close the file and reopen it, it does it again. These files are on BIM 360 Docs, so our suspicion was that it's a BIM 360 thing. We sort of verified this by saving the file to our local network and opening it outside of BIM 360. This copied file works as expected without having to Audit it and allowing edits to be made to the pipe network.
Is there something happening in the save function to BIM 360 that would corrupt this?
