Hi @aortiz9PQVW,
I am not sure if you are in BIM 360 Docs or Autodesk Docs. So I have posted both for you.
BIM 360 Docs
In BIM 360 Docs can do export a report a project activity log directly from the Project Admin > Services > Document Management > Activity. This will give you a log of activity on the project.
How to export a Project Activity Log
You can generate a log of all documents in a given folder or subfolder in BIM 360 Docs but I am not sure if it will list what has been shared only the files within the folder. It is possible do it for individual files by clicking the three dots after document file name and selecting View file activities.
How to general an individual file activities log
Autodesk Docs
Now in you do not have the options to export a project activity log directly from the Project Admin. So you will need to go to the folder and file you require an activity log from. Select the three dots on the right of the file and select View file activities. Similar to BIM 360 Docs.
The final option it is possible you could get the information from Insights Data Connector as this does provide project data such as daily logs, but I have never checked to see if it can. So you will have to test it out.
I hope this helps.
Please click the Accept Solution button if my reply answers your question.
Twitter: @TheDarkAsset
LinkedIn: gareth-spencer-84202532
Gareth Spencer
BIM Technical Consultant | Man and Machine (UK)
