BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
Revit Project loading through BIM 360
8 REPLIES 8
Message 1 of 9
jason.wells
524 Views, 8 Replies
When my team tries to open Revit project through the BIM360 Hub within Revit it take upward of 10 minute to open. the files sizes are 193,196 KB. Is there anything on my network side that could be causing the issues
8 REPLIES 8
Message 2 of 9
Hey Jason,
That sounds long for the file size. Could you add some more details please like
  • has this been faster before?
  • do you see that just with this file?
  • is it one ore several linked files?
  • are you using BIM 360 Team or BIM 360 Document Management?
  • which Revit version?
  • the model has been initialized for cloud worksharing?
  • do you have Revit Accelerator installed?
Best regards,
Markus
Markus Briglmeir, Product Manager BIM 360 Design Collaboration
Message 3 of 9
It is faster when I am home than in the office. I will check on the Revit acceloritor
Message 4 of 9
All right. You might as well have a look at the Revit Cloud Worksharing forum. You'll find some related posts like
https://forums.autodesk.com/t5/revit-cloud-worksharing-forum/the-revit-accelerator-for-c4r-how-does-...
Best regards,
Markus
Message 5 of 9
Hi @jason.wells,
I'm just checking in to see if you need more help with this. Did the suggestion that @markus_briglmeir provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
Message 6 of 9
jason.wells
in reply to: anil_mistry
How can I confirm I have the accelerator installed?
Message 7 of 9
anil_mistry
in reply to: jason.wells
Hi @jason.wells,
Please, see "Manage the Revit Server Accelerator Connection" article for more information about Revit Accelerator. Let me know if this helps.
Anil Mistry
Message 8 of 9
jason.wells
Interesting so you use a Revit Server to link to the C4R BIM 360 system?
Message 9 of 9
Hi @jason.wells
You are absolutely right, this one is the correct post:
Best regards,
Markus
