BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
Revit Linked Model Upload
5 REPLIES 5
Bnilath
609 Views, 5 Replies
Bnilath
Revit linked model upload tooking long time to process. Please advise.
5 REPLIES 5
Jason_Kai_Jiang
in reply to: Bnilath
Jason_Kai_Jiang
Hi @Bnilath,
The log system indicated that the extraction of the linked Revit files (including 20 linked files) were completed after 5 hours 44 mins.
Thanks and bet regards,
Jason Jiang
Autodesk BIM 360 Document Management team
Jason Jiang
Senior Product Manager
Hi @Bnilath,
Jason Jiang
Jason Jiang
anil_mistry
Autodesk Support
Autodesk Support
Hi @Bnilath,
I'm just checking in to see if you need more help with this or @Jason_Kai_Jiang's findings on this helps you.
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
Hi @Bnilath,
Anil Mistry
Bnilath
in reply to: anil_mistry
Bnilath
I can’t consider this as a solution. Its tooking almost 6 hours to complete the uploading process.
james.l.bryant
james.l.bryant
Hello @Bnilath,
Thank you for contacting the Autodesk Forums and Support.   My name is James Bryant of Autodesk Support and I created case # 14435421 to this matter.  I will be reaching out to you by email to resolve your questions/issue.  An update will be posted here once our issue is resolved.   Thank you
James L Bryant
Autodesk Support Team
Contact Autodesk |
Hello @Bnilath,
James L Bryant
Contact Autodesk |
james.l.bryant
Thank you for taking time to contact Autodesk Forums and Support.  I will now close this discussion per case 14435421.   Please let us know if we may be of future assistance.   Thank you
James L Bryant
Contact Autodesk |
James L Bryant
Contact Autodesk |
