Witam,
- utworzyłem nowy projekt w BIM360 Document Menagement;
- przydzieliłem uprawnienia użytkownikom;
- utworzyłem folder "revit" do którego:
- wgrałem plik revit nr1;
- wgrałem plik revit nr2;
- otworzyłem plik revit nr1 w programie revit (z dysku BIM 360 poprzez Autodesk Desktop Conncetor);
- spróbowałem w pliku nr1 podłączyć plik nr2 (z dysku BIM 360);
- nie działa;
W załączeniu screen, proszę o pomoc, co robię źle.
Pozdrawiam,
Adrian
Witam,
- nie działa;
Pozdrawiam,
Adrian
Solved by anil_mistry. Go to Solution.
Hi @Anonymous,
Translation (via Google Translate):
- I created a new project in BIM360 Document Management;
- I have delegated rights to users; - I created the "revit" folder to which:
- I uploaded the revit file nr1; - uploaded revit file nr2;
- I opened the revit # 1 file in the revit program (from the BIM 360 drive through Autodesk Desktop Conncetor);
- I tried file No. 2 in the file No. 1 (from the BIM 360 disk);
- did not work; Attached screen,
please help me, what I'm doing wrong. Greetings, Adrian
@anil_mistry translated your question per the above as this is predominantly an English forum.
Thank you for participating in our Community! I was wondering what version of Desktop Connector you are using? Development team has corrected similar issue in latest version 8.0.1.710 of Desktop Connector. I would suggest to try updating to latest version and then try again. Let me know if this helps.
Thank you and have a great day!
Hi @Anonymous,
Hi @Anonymous,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Hi @Anonymous,
