BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
Raster images published from Revit published Sets to Autodesk Construction Cloud display
1 REPLY 1
brucegund
142 Views, 1 Reply
Trying to get our team to use the ACC workflow from Revit to ACC for review, communication, and print. Team member asked about publishing from Revit workshared cloud models with setup Publish settings, images are not displaying. The team is using linked images in a few views placed on Sheets. Is there a better workflow to get the images to be published? Are all raster images an issue? Would a linked pdf work better?
Bruce
1 REPLY 1
Yien_Chao
in reply to: brucegund
Hi
If it's an image link,  make sure everyone have access to the path.
Otherwise try to save the image in ACC's folder and link it from there to Revit before publishing.
Technology Administrators
