BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
Plan Thumbnail is in color and the sheet is black and white
1 REPLY 1
820 Views, 1 Reply
After publishing the model and reviewing the sheets the thumbnail of the sheet shows everything is in color.  However, when I open the thumbnail sheets is black and white...  Does anyone know how to change this setting to show full-size in color?  We need to have the full-size sheet show in color so that the people reviewing them know which element belongs to which concrete pour...
Thank you,
Timothy
1 REPLY 1
Apparently, the issue has to deal with your DWF settings.  I exported a sheet to DWF from the model and it appeared black and white again...  When I exported a 2nd time I checked the print settings and for some reason, it was set to Black and White.  I change the setting to color and the DWF appeared in color when I brought it into 360 Docs.
I saved my model and republished it to BIM 360 Docs and checked the sheets again.  Now everything appears to be good.
Check your DWF printer setting if you have the same issue.
