Hi Team,
Is it possible to Replace/override a Revit sheet with a PDF sheet in bim 360 docs?
Thank you
Lalitha
I assume you uploaded sheets to the Plans folder, these are "NOT" part of a collaborated (Project Files folder) model. You should be able to manually overwrite the sheet.
Steps:
If this helps answer your question - please mark with 'Accept as Solution'.
Thank you,
-Scott
If the root issue is you were having some trouble managing your sheets - some additional info - see our best practices FAQ on working with sheet sets:
BIM 360 Docs Publish Set Best Practices
-Scott
I haven't heard back from you, please let me know if you have any further questions. If my previous responses answered your question, please mark with 'Accept as Solution' to improve the find-ability of solutions for users that may have a similar question.
Thank you,
-Scott
