Hi, @lim.wendy
We are using Model coordination at the moment. We created a 3D view in Revit for MEP and another one for structure for a part of the model (section 1). Within Model Coordination we combine these 2 Revit views into one Model Coordination view. This works fine. So we created a number of issues.
However, the size of the 3D has to change and a second section has been made. Therefore, in Revit the 3D views are modified. Again we use the old Model coordination view and now we see a number of issues that are outside the region. I can not move them to another Model Coordination view.
So now, the only thing I can do is Close the issue and recreate them in the other Model Coordination view.
Is there another way of doing this???
Gr. Renzo
Hi @Renzo_van_Rijswijk ,
Thank you for reaching out. I've reached out to the support team and they'll contact you for further information.
Hi @Renzo_van_Rijswijk !
I'm Marta, a Technical Support Specialist.
Thanks for this inquiry. Your case has been escalated, and we'll be taking a closer look at this behavior on a support case.
I will keep you updated!
Thanks again!
Best regards,
