Mark-ups don't seem to be editable. If you add text while zoomed out the text is large. If you add text while zoomed in the text is small. At this point you have to be perfect with your mark-up as it doesn't appear that you can delete, modify the size or hide them permanently.
If mark-ups cannot be resized or deleted, please add this feature.
If they can, please provide instructions.
Solved by joan_allen. Go to Solution.
Is it possible to edit the text of markups, after save the markup?.
Bernardo Enriquez
Civil Engineer
BIM 360 Docs supports the ability to edit and archive (delete) markups, including the ability to edit a text markup. For more details, please refer to these release notes from August: https://forums.autodesk.com/t5/bim-360-docs-release-notes/bim-360-docs-update-august-17-2017/ba-p/72...
Best Regards,
Joan Allen
Autodesk BIM 360
the note isn't available anymore. I'm still not able to edit or delete a text mark-up in a pdf, if it's already accepted.
If it's possible, please provide some instructions.
Many thanks in advance,
Janina
