BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
HTML character codes coming through for special characters in sheet names
5 REPLIES 5
aaronwagner
747 Views, 5 Replies
Example below "%2F" coming through when OCR/parameters extraction reads forward slash:
I'm not sure if this occurs on other codes/characters.
Aaron Wagner | Technology Consultant – Autodesk Construction Business Line Lead
U.S. CAD | Achieve More
Rocky Mountain Region, Denver, CO
T: 877-648-7223 x301
5 REPLIES 5
Hi Aaron,
Thank you for your post.
How was the file uploaded, were this individual files?  I suspect that it is one PDF file with multiple sheets.
Do you happen to have a sample file you can provide for review?  If so, please send it to me at frederick.regala@autodesk.com.
Frederick
Frederick Regala
Deployment Specialist - ELearning Content Creator
Autodesk Construction Solutions
I tried two things:  upload Revit file to “Project Files,” and upload directly to “Plans.” The Revit file I used was the basic sample project that ships with Revit (see image below).  When I uploaded the Revit file to Project Files, plan views weren’t generated except they are available when browsing the file itself.  Those views correctly list the forward-slash.
However, when I uploaded the RVT to Plans, the sheets generated contained the HTML code:
Hi -
Thank you for providing the additional information.
I will investigate and inform our Dev team of this issue.
Updates to follow.
Frederick
Frederick Regala
Hello Everyone,
As an update.  This issue has been resolved.  It will be included in the next update of BIM 360 Docs which will take place in the coming week or two.
Frederick
Frederick Regala
Hello Everyone!
Just to close the loop on this issue.  An update to Docs was pushed out last night which included the solutiion for this issue.
Sheet names with forward slash from Revit is extracted in Docs with the forward slash appearing as expected.
I verified this moments ago.
Thank you !
Frederick
Frederick Regala
