BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
How do I extract/export a page from revit or autocad to PDF?
2 REPLIES 2
718 Views, 2 Replies
How can I take a page in Docs that was a revit or autocad file and has markups and send it to someone by email?  I only see the Export option on PDF's but that gave errors when I tried to use it.
2 REPLIES 2
Jason_Kai_Jiang
Jason_Kai_Jiang
Hi @Anonymous,
After you open a Revit document by BIM Viewer, you can print it.
In the print setting GUI, you can select to print it as PDF. Markup can also be printed into PDF.
Thanks and best regards,
Jason Jiang
Autodesk BIM 360 Document Management team
Jason Jiang
Senior Product Manager
Hi @Anonymous,
Jason Jiang
Jason Jiang
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @Jason_Kai_Jiang  provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
Hi @Anonymous,
Anil Mistry
