Hello guys,
Is someone experienced this before?
We are trying to get back to older version of revit file to re-publish that version and we cannot retrieve it. The system is showing error (in dialog box) "Failed to open document".
All responses will be highly appreciated.
Alfonso
zapatero.alfonso@ong-ong.com
Hello guys,
Alfonso
Solved by zapatero.alfonso. Go to Solution.
Thank you for participating in our Community! Are you trying to open this Revit model from BIM 360 Document Management project? Are you seeing this behavior with this specific model or all models? Can you view this model in BIM 360 Docs?
Thank you and have a great day!
Only for this model and I can retrieve other older versions (V2-V4,V6-V9). Only the version 5.
What could be the problem?
Sorry for delayed reply. Can you view this model in BIM 360 Docs? Have you tried downloading source file and then importing again?
I was wondering are you still seeing this behavior? Please let me know if you need additional assistance.
hi..I can download and open now. No more problems. thanks for all who commented on this issue.
