BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
DWG shows all layers
5 REPLIES 5
hallgrimurmar
760 Views, 5 Replies
Hi
When uploading DWG files into DOCS all layers are automatically unfrozen and on.  This causes the files in BIM360 to not be visually correct.
With regards
Hallgrimur
Tags (3)
5 REPLIES 5
in reply to: hallgrimurmar
Hello @hallgrimurmar ,
Did you try using the "Layer Manager" (see below)?
Let me know if this helps 🤔
hallgrimurmar
Hi @Anonymous
I seem to have no control over XREF layers in the "Layer Manager".  Cannot turn them on or off.
I should also not have to do that. It should look the same in BIM360 as when I saved it in AutoCAD.
with regards
Hallgrimur
oloaiza
I dont know if this information is still useful, but what you can do is turn the layers off with the Freeze and  VP freeze tool in de cad file, that works for me.
Hope this can help you
Did you find a solution to this problem? None of the answers posted here are correct.
BIM360 can be grumpy at times. Reloading or re-uploading the file may improve the symptoms.
Please click the Accept Solution button if my reply answers your question.
こちらの投稿は役に立ちましたか?良ければ「いいね」お願い致します!
こちらの投稿があなたの問題解決に寄与した場合、「解決策として承認」ボタンのクリックへのご協力をお願い致します。
Yoshiyuki Miyauchi / 宮内よしゆき
openBIM Architect
ONESTRUCTION Inc. Co-Founder & CTO
buildingSMART Japan IFC利用支援小委員会 委員長
bSI BIM Professional Certification | BSI BIM Project Information PRACTITIONER | BSI BIM Asset Information PRACTITIONER
Civil User Group認定インストラクター
y.miyauchi@onestruction.com | TEL:050-3528-8052
Twitter|LinkdIn
