Document Log tool has been added to BIM 360 Document Management.
It creates a Document Log Spreadsheet of files withing a folder.
+ (plus)
It works for both "Plans" and "Project Files" sections
It logs files in the folder you select.
It logs attributes of any type of file format that is on BIM 360.
The files are hyperlinked to BIM 360 in the Spreadsheet.
It shows the Folder path to the file.
Δ (delta)
It would be great that the log contained files in subfolders, it doesn't do that at the moment.
The log spreadsheet does not contain number of Markups, Issues, RFIs nor any Custom Attribute Field.
@joan_allen Great job on the recent update of the Document Log, it's a great tool.
I din't see a release note (http://blogs.autodesk.com/bim360-release-notes/) so I wanted to share this with the forum and with my team.
Solved by joan_allen. Go to Solution.
HI @Anonymous Thank you for the feedback! This is a brand-new feature, and here are the detailed release notes: http://blogs.autodesk.com/bim360-release-notes/2018/11/03/bim-360-docs-update-october-31-2018/
For now, this supports a single folder (any folder type) at a time, and the standard metadata only. We plan to add custom metadata (attributes) and subfolders in a future update.
Best Regards.
Joan Allen
Autodesk BIM 360
Hi Joan,
Do you have anymore information regarding the future update on the document log that will include additional attributes? This really would be a great option to have.
John
Hi Joan,
When exporting a document log will attributes be exported too?.
I have an issue where document log had excluded attributes i had processed through the title block extractor.
Sean
is it correct that I can't see also project review "Status" in the log file? is not this a standard metadata?
you can see screen of BIM 360 and Log file.
Thank you
Regards
Marco
I too would like to add my voice to having specifically the attributes to be exported.
Hi Joan,
Would you mind giving me and the community an update of the subfolder-search ?
I'd like to implement subfolders into this.
Kind regards, Ruud.
Really needing an update to export document log across folders and subfolders.
Anyone have a position concerning this issue. Would be possible to use Forge on this?
Alex
@joan_allen similar to @ghezzi.mar I would of thought that the Workflow review status would be included in the custom meta attribute update in the document log? Is this on the roadmap for inclusion in the document log.
We would find this very useful as a quick way to print out log to identify the status of documents for discussion in meetings.
Can you give an update about when to expect.
Hi All,
Just want to reinforce the need for document log to include subfolders.
Alan
Really need to show the status of the Documents in the logs. The option to list the sub-folders documents is highly appreciated too.
Hi Joan,
Does it make sense the request of exporting the metadata of the documents and files on the "Document Management" which is by default from its name takes more than 18 months?
Its a basic of the document management to export all the related metadata to help projects parties to see the full picture and make the correct decision.
Dear Colleagues,
Can anyone advice why the report sent to me after the Document Log is empty?
