URL links to other documents uploaded to BIM360 within the properties of a model uploaded to BIM360 are working from a PC but not from an Ipad.
Is it possible to have working links when viewed via the BIM360 app on a tablet ?
Thanks Lee
Hi @LeeUUSLM
Thank you for your post. My name is Michelle and I'm from Autodesk Technical Support.
Could you explain what you mean exactly by URL links? Do you mean Hyperlinks to other documents in BIM 360 Document Management or do these links lead to objects in Revit?
Would you also list your step by step workflow how you created the links so that I can test it on my side?
I'd also like to know whether you uploaded your files to the Project Files folder or the Plans folder and which version of the BIM 360 mobile app you are using?
Thank you and best regards,
Michelle
