Hi All
Can I change the location of the desktop connector files from my C drive to another Drive? if yes how?
Thank you
Hi All
Thank you
Solved by bogdan_ciobanu. Go to Solution.
@Anonymous
Thank you for your post.
I do not think it is possible to change where the connected drives are installed, but I will double check with our engineers.
Also, maybe you would like to share the reason you would like to change where everything is installed? Just to make sure we got the whole picture here.
Thank you!
Best regards,
Bogdan
@Anonymous
Thank you!
Best regards,
Bogdan
@Anonymous
I have double checked with our development team and, yes, I have confirmed that at the moment we cannot choose where to install Desktop Connector.
I have also logged an improvement request, so maybe we will see this implemented in the future.
I hope this was helpful.
Best regards,
Bogdan
@Anonymous
Best regards,
Bogdan
Hi!
I have the same problem with the install location. Have you solved this issue already?
Thanks.
Hi!
Thanks.
In the latest version of Desktop Connector, the installer allows the ability to change the install location (Options button in the installer):
You can download the latest version here:
https://help.autodesk.com/view/CONNECT/ENU/?guid=GUID-847CE3FC-B26F-46B8-895E-5D825F4BD540
Matt
Matt
This is great! Thanks to Autodesk for providing a solution to this. I wrote about this on my blog, BIM Chapters:https://bimchapters.blogspot.com/2019/07/autodesk-desktop-connector-update.html
False alarm... turns out this is just for the install location of DC, not the local cache files. Sorry:(
A Little investigation of some of the control files in your User area
eg... C:\Users\Richard\AppData\Local\Autodesk\Desktop Connector\v4\Data Source Instances\BIM 360
You will find a file called Instance.xml
Inside that file you can alter the location of the Cache to where ever you want. Stop the Desktop connector first then make the change and restart desktop connector.
eg.. my default location as below and then altered
WorkspaceLocation="C:\Users\Richard\BIM 360"
WorkspaceLocation="E:\BIM360"
Richard.
Richard.
I've done this and it seems to have worked.
I was able to relocate the BIM 360 local files using another method and it has been workign for several months now. Editing that file might get replaced with updates? Here is what I did: https://bimchapters.blogspot.com/2019/05/move-bim-360-cache-files-to-another.html
Did you have to first create a folder E:\BIM360?
I did, yes. I created a separate partition to hold all of the BIM 360 files. I went ahead and moved Google Drive, OneDrive, etc to that drive as well.
Richard, Thanks for the tip on changing path in the Instance.xml file. This has changed the path but I'm still seeing the BIM 360 drive in C:\Users\John.Buxton is this correct?
Hi @john.buxtonLVQ8H
After you change the route in the Instance.xml file, you should see BIM360 in your other hard drive.
If that's not happening just check if the path has been change in the Instance.xml file, then sign out and exit the Desktop connector and open it again, after that you should be able to see it on you other hard drive.
if that doesn't work, try to sign out and exit the app before changing the Instance.xml path.
I have added a feature request also.
https://forums.autodesk.com/t5/bim-360-ideas/desktop-connector-local-file-location/idi-p/9814021
It works perfect
thanks a lot
It works perfect
thanks a lot
"Change Workspace" command has been added to the product with the latest release (15.6.0) which is now available for download.
The latest version I can see online is March 23, 2022 (v. 15.5.0.1684)
Do you have a link to the new version?
