Delete a project
Delete a project
Delete a project
Just wanted to know how to completely remove a project?
I know that we can make a project Archived, but that's not removing a project.
Thanks.
sebastian.wilcots
I have just received your case that you submitted regarding your issue with deleting projects from your account. At the moment it is not possible to remove your project, but if you would like to make an enhancement request of this function, you may visit http://forums.autodesk.com/t5/bim-360-ideastation/idb-p/2032 to have your question submitted for further review.
alexandrem
You can deactivate a project using the account admin interface, so the project won't show in the BIM 360 Docs project list anymore.
HTH
Pshupe
How would you do that?  Ideally I would also like to delete a project but if this is as close as we can come that is fine.  I am the Account Admin and can't seem to find where to Archive or Deactivate the project. Thank you in advance.
Regards Peter.
sebastian.wilcots
At the moment, there is no way to remove projects from your BIM 360 Field account.  Setting the project as Inactive will remove the project from your active list of projects, but you would like to see a change to add this feature, you may submit an enhancement request at http://forums.autodesk.com/t5/bim-360-ideastation/idb-p/2032 were our engineers will look into the request further.  Please let us know if you have any questions and we will assist you.  Thanks.
joan_allen
Here is how you can deactivate (not delete) a project in BIM 360 Docs.  Go to "Account Admin" and select a project.  Then select the "Profile" tab, and you will see your project information with the ability to change the status of the project:
Best Regards,
Joan Allen
Autodesk BIM 360
Joan Allen
Sr. Group Product Manager
Link Name | Link Name | Link Name | Link Name
sebastian.wilcots
Thank you Joan!
