Just wanted to know how to completely remove a project?
I know that we can make a project Archived, but that's not removing a project.
Thanks.
Thanks.
Solved by joan_allen. Go to Solution.
I have just received your case that you submitted regarding your issue with deleting projects from your account. At the moment it is not possible to remove your project, but if you would like to make an enhancement request of this function, you may visit http://forums.autodesk.com/t5/bim-360-ideastation/idb-p/2032 to have your question submitted for further review.
You can deactivate a project using the account admin interface, so the project won't show in the BIM 360 Docs project list anymore.
HTH
HTH
How would you do that? Ideally I would also like to delete a project but if this is as close as we can come that is fine. I am the Account Admin and can't seem to find where to Archive or Deactivate the project. Thank you in advance.
Regards Peter.
Regards Peter.
Here is how you can deactivate (not delete) a project in BIM 360 Docs. Go to "Account Admin" and select a project. Then select the "Profile" tab, and you will see your project information with the ability to change the status of the project:
Best Regards,
Joan Allen
Autodesk BIM 360
Best Regards,
Joan Allen
Autodesk BIM 360
Thank you Joan!
