BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
Copying Checklists, Not Just Checklist Templates
4 REPLIES 4
628 Views, 4 Replies
I have looked on the forums and this specific problem/feature does not seem to have been asked about before, but I could be wrong. I did not want to post this in ideas in the case something similar to what I am looking for already exists.
There are many parts that require the same people assigned to every part of a checklist, but have different names.  Adding new assignee's takes a long time when the drop down takes minutes to show up each time, and you must add a different assignee to 10 or more different sections for 20 different checklists.
If there was a way to copy a checklist in its entirety, including assignee's for individual sections, then you would only need to change the location and name of the checklist and would save a large amount of time.
If anyone knows if there is a way around this problem that already exists, or if there is nothing to be done to improve efficiency here, I would greatly appreciate it!
Tags (1)
Labels (2)
4 REPLIES 4
renata.demuro
Hi @Anonymous,
Thanks for your post! I believe I found a related post in our BIM 360 Idea Forum to this: Define checklist assignee directly on template. Does that post match with the feature you are requesting?
If this answers your question, please click the "Accept Solution" button so others may benefit from your post. If not, I'm here and happy to answer any questions. Thanks!
Renata DeMuro
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
in reply to: renata.demuro
Thank you for your help, this is exactly what I was looking for!
renata.demuro
Hi @Anonymous,
Awesome! Glad I was able to help. Have a great rest of your day 😃
Renata DeMuro
Autodesk, Inc.
mikako_harada
FYI - moving this post to BIM 360 product forum as this is question about product feature.  (not API)
Mikako Harada
Developer Technical Services
Technology Administrators
