Changing back to BIM 360 Glue from Model Coordination
I have noticed that when setting up a project you have an option of selecting Model Coordination or Glue. Is it possible to change and project that was set up with Model Coordination back to Glue?
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for participating in our Community! That's correct if you activate project for Model Coordination then you can't revert back to BIM 360 Glue. I would suggest creating parallel project in Glue and Model Coordination and when you are comfortable to switch to Model Coordination then you can archive Glue project and continue with Model Coordination project. Let me know if this helps.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Thanks, yeah that's exactly what I ended up doing. Thanks for the feedback, would definitely like to see you be able to change it.
mlwellhausen
Anil,
Are we able to start Model Coordination and GLUE on the same project yet? Its an issue for us to test Model Coordination since we need GLUE for layout. I'd like to work with Model Coordination on a current project, but we have already started GLUE on that project and live working models are posted, so starting a duplicate project is not an option.
matthew.wellstein
Yes! As of this week, the Services page in Project Admin has been overhauled. You can now activate Model Coordination and Glue in the same project. More generally, any Classic and Next Gen service can be activated side-by-side from the new Services page.
You can read all about it in the release notes here: https://blogs.autodesk.com/bim360-release-notes/2020/05/21/bim-360-admin-update-may-20-2020/
