BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
Can't create a package
6 REPLIES 6
Raghavendra_Bhat
1296 Views, 6 Replies
When i try to create a new package i get this error message. See attached image
6 REPLIES 6
Seems to be a similar problem like in this post: https://forums.autodesk.com/t5/bim-360-design-collaboration/bim-360-docs-downstream-service-request-...
Cannyou check the deleted Files in the shared and consumed folder in BIM360 Docs whether you find fules without a version.
-Martyn
Martyn Messerli
Software Engineer
Hi @Raghavendra_Bhat,
I'm just checking in to see if you need more help with this. Did the suggestion that @martyn.messerli provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
Hey Martin, When I got into Design collaboration it prompted me to fix missing folders and that got working.
But I see there seems to be some kind of mystery to delete any teams once created. If I try to clear the list by deleting few team names that are no longer required, BIM 360 design just deactivates it but actually doesn't permanently remove it.
Is there a way I can clean up all the team names and start defining them fresh. Considering I do not have any files added to these folders yet.
@Raghavendra_Bhat at this point, there is not an option to delete a team from the history, just deactivate.  Of course, this is a good suggestion that we will consider moving forward.  For the time being, we do show deactivated teams grayed out and italicized so you can visually see the difference between them and active teams.
Adam Peter
Customer Program Manager
@Raghavendra.Bhat Thank you for that question. To make it short, no, there is no way to delete teams. You can only deactivate them.
We do have plans to also support deleting teams from BIM360 Design Collaboration which have never been contributing. But be aware, the folder which have been created to introduce those teams, cannot be complete deleted. As soon this feature is available this can be performed on existing projects.
I have added this as an IDEA so you can vote for it. Adding votes will increase the likelihood that this will be added next: https://forums.autodesk.com/t5/bim-360-ideas/design-collaboration-allow-deleting-teams-which-have-ne...
I hope this answers your questions.
-Martyn
Martyn Messerli
Software Engineer
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Thank you and have a great day!
Anil Mistry
