I would like to use BIM360 Layout.
If I purchase BIM Collaborate, will I be able to use BIM360 Layout on my iPad?
Or do I need to purchase BIM Collaborate Pro?
Solved by Elmoataz.Bellah.Salem. Go to Solution.
what you want exactly to do so that we can say need Collaborate Pro or Not??
Information from surveying instruments will be connected to ACC to accelerate surveying operations in the field using tablets.
Are there any differences in functionality between BIM Collaborate and BIM Collaborate Pro when using BIM360 Layout?
okay, i see your need .
the main difference between Collaborate and Collaborate Pro is the Cloud Worksharing for Revit, Civil 3d and Plant 3D
