Hi Experts
Would you tell me against my question?
My question is
After download files from BIM360 Docs project to iPad as bellow image, can user copy the data from iPad to PC by using PC application directory?
My expectation is, even though connecting iPad and PC, user can't open the file from PC by security reason.
Solved by Jason_Kai_Jiang. Go to Solution.
If the iPad device is not rooted, users cannot obtain the downloaded contents of BIM 360 Docs iOS app by connecting the device with PC.
Best regards,
Jason Jiang
Autodesk BIM 360 Document Management team
Thank you for your quick answer to me. I could understand this.
Thank you
