BIM 360 Model Coordination: Filter between 2 dates
johan.cantryn
johan.cantryn
In de models tab you have some options to filter the list of models. One of them is "Date" where you can pick one date.
Most of the times you don't want to filter a specific date, but you want to filter all models in between 2 dates.
richardparker
Hi Johann, the current date picker does let you select a date range. Click once to select the start date (it will be highlighted in orange) and again to select the end date. I will let our UX team know that this is not immediately apparent to a user.
Richard
johan.cantryn
Hi Richard,
Thanks, nice way to select 2 dates within a simple interface.
In my opinion you should definitely not change the UI, just change the title. Now it is "Dates", when you change the title to "Choose between dates" it should be clear enough.
Thanks a lot for your feedback.
