i´ve a problem by using the attributes.
The order of the attributes totally changed. By itself. First I thought it came up by using
another PC, different display size, etc.
But then I rememberd I started a review task. The standard "approval status" attribute moved forward and all the custom attributes moved to the end after finishing it.
Can´t set the attributes order to default just reorder it manually.
This can takes hours to that. I don´t want to think about having that on several projects.
This was just a sample project.
Managing attributes and also losing them by creating a new project from a template is so stupid and annoying.
Are there any suggestions about that?
Thank you!
