BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
BIM 360 - AutoDesk Construction Cloud - Model Coordination
5 REPLIES 5
treed_sazan
298 Views, 5 Replies
Good afternoon all,
So in BIM360, we had the Model Coordination area to setup coordination spaces. Where is that in ACC? Is that not available? I notice that I still have the ability on projects labeled BIM360 projects, but on the newer ACC projects with the newer interface, there is no area. I appreciate any feedback. Also in regards to that, does Coordination spaces have to rely in a folder called coordination? (And are people just duplicating the model for this?)
Tricia
5 REPLIES 5
Yien_Chao
in reply to: treed_sazan
Hi
You will need to activate the module model coordination by members to give them access.
And yes its by folders, you can create as many coordination spaces as you like.
treed_sazan
in reply to: Yien_Chao
Thanks, was definitely a little convoluted to find. I see the access module now, and then the ability to create the spaces in the settings. It took me quite a few sites to find a small Autodesk University paper on the creation of this. And how it takes it a few minutes to sync the models that need to put placed in a separate Coordination folder and then that folder pathed for the spaces. I got it working. Appreciate the answer.
yes , you can do it in Model Coordination Module
1-go to Model Coordination
2-Go to setting
3-create you space coordination name and location
4- you can switch between space coordinations
Elmoataz Bellah Salem
AEC Technical Specialist | Autodesk Expert Elite | Autodesk Ambassador Gold Level | ACP | ACI
Thank you, yes, as described above, I finally found it. 😊 I appreciate the follow up.
You are welcome
