3D Section View Error and Glitches
Message 1 of 12
When slicing a 3D model, in this example a Revit file, it is common for the view to glitch and the section to almost catch on objects. See the examples attached.
This is particularly frustrating when trying to section down to the ground floor and there doesn't seem to be anyway around the problem.
Regards
Jonathan
Replies (11)
Message 2 of 12
bogdan_ciobanu
Autodesk Support
Autodesk Support
@Anonymous
Hello Jonathan,
My name is Bogdan, I am with the BIM 360 Technical Support Team and I will be assisting you on this issue.
I understand that when you are slicing a 3D model in BIM 360 Docs, there are some errors in the way that objects are displayed, as presented in the screen-shots you attached to this post.
Could you please let me know if this is always happening to you or if this is happening just for some of your projects and for some of the uploaded 3D models?
Also, may I please ask you to upload the Revit model on which you are currently working in BIM 360 Docs? I would like to investigate it on my side and see if I obtain the same result.
Thank you very much.
I look forward to hearing back from you soon.
Best regards,
Bogdan Ciobanu
Bogdan Ciobanu
Message 3 of 12
Hi Bogdan,
What is your email shall I give you access to my Docs site to access the
model. It doesn’t happen to every 3D model but quite a few.
Regards
*Jonathan Conway*
3D Services Technician
*Hobs Reprographics*
35 Dale Street, Manchester, M1 2HF
0161 233 1943 HobsRepro.com*I* HobsStudio.com*I*
*[image: Architecture_Engineering_Construction_Collection_2017
copy]*ARCHITECTURE,
ENGINEERING & CONSTRUCTION COLLECTION
One essential set of BIM tools for building design, civil infrastructure
and construction
This electronic message contains information from Hobs
Reprographics plc which may be privileged or confidential.
Any opinions expressed in this communication are not
necessarily those of the company.
Registered Name: Hobs Reprographics plc
Place of Registration: Registered in England and Wales
Number: 511368
Registered Office: Vanilla Factory
Message 4 of 12
bogdan_ciobanu
Autodesk Support
Autodesk Support
@Anonymous
Hi Jonathan,
I sent you a private message with the requested information.
Please add me to your project so that I will continue investigating this issue on my side.
Thank you.
Best regards,
Bogdan Ciobanu
Bogdan Ciobanu
Message 5 of 12
@Anonymous
Hi Jonathan,
Thank you for your patience while we investigate this issue.
I can confirm that I recreated the behavior on my side, but it happens only for this particular project of yours.
May I please ask you to upload the Revit model so I that I can take a look at it, too?
Thank you and I look forward to hearing back from you soon.
Best regards,
Bogdan Ciobanu
Message 6 of 12
bogdan_ciobanu
Autodesk Support
Autodesk Support
@Anonymous
Hi Jonathan,
I am soryr for my previous post, wrong accoung :). I will re-write everything again, so that the system will record it.
Best regards,
Bogdan Ciobanu
Bogdan Ciobanu
Message 7 of 12
bogdan_ciobanu
Autodesk Support
Autodesk Support
@Anonymous
Hello Jonathan,
Could you please confirm in a private message the name of your account and let me know on which server the project is hosted (US or EU)?
Unfortunately, I cannot recreate this behavior on my side on other projects, only on yours. So, once again, could I also ask you to send me the Revit model you were working on?
I would ask the development team to investigate this issue, but to do that I would need the requested information.
Thank you,
Best regards,
Bogdan.
Bogdan Ciobanu
Message 8 of 12
bogdan_ciobanu
Autodesk Support
Autodesk Support
@Anonymous
Thank you for your patience while we work on finding the cause of this behavior. Unfortunately, we are going to need more time to investigate this issue.
I will get back to you as soon as we have an answer.
Best regards,
Bogdan.
Bogdan Ciobanu
Message 9 of 12
bogdan_ciobanu
Autodesk Support
Autodesk Support
@Anonymous
Thank you again for your patience while we are trying to identify what is causing this behavior.
Unfortunately we haven't get to a result yet, so I will have to kindly ask you to wait a little more. Thank you for your understanding.
Best regards,
Bogdan.
Bogdan Ciobanu
Message 10 of 12
bogdan_ciobanu
Autodesk Support
Autodesk Support
@Anonymous
Once again I am sorry for this is taking so long to investigate. Our development team is doing it's best to find the cause for this behavior.
I will get back to you as soon as the investigation is complete.
Thank you for your patience.
Best regards,
Bogdan Ciobanu
Bogdan Ciobanu
Message 11 of 12
bogdan_ciobanu
Autodesk Support
Autodesk Support
@Anonymous
Thank you for your patience while our development team is still working on this request. Apparently this is a quite difficult issue to solve.
I will get back to you as soon as the investigation is complete or with an update on the work progress.
Best regards,
Bogdan.
Bogdan Ciobanu
Message 12 of 12
bogdan_ciobanu
Autodesk Support
Autodesk Support
@Anonymous
Thank you very much for your patience. We have just received an update from our development team. Unfortunately, there seems to be an issue with the Viewer that BIM 360 Docs uses. I have tested, and the same behavior occurs if using A360.
Our development team is currently working on improving the functionalities.
As this request is now logged with the development team I will now have to put this case on hold. I am sorry for the inconvenience and I hope the Viewer will soon be improved.
Thank you very much for your understanding.
Best regards,
Bogdan.
Bogdan Ciobanu
