What is the correct method to custom textures in Revit BIM360 environment?
juho.tastula
Message 1 of 1
juho.tastula
Hello.
This topic has a couple of threads, but there seems to be a lot of confusion how this problem should be handled. So I am asking for explanation for following question.
How Autodesk wants us to setup materials with custom textures in Revit BIM360 work environment for multiple users?
Currently
- Material textures links are broken by the desktop connector because for some reason material links include the username in the folder path. (this seems completely artificial and unnecessary limitation because for example dwg-links work just fine?)
Are we missing something or is just a core functionality missing when using Autodesk only work-environment? 🙂
Thank you in advance for your answers.
Replies (0)
