Unable to upload checklist template Next Gen
s.odwyer
Message 1 of 10
s.odwyer
I keep getting an error that i cannot upload a checklist to Next Gen saying the server is having issues.
Import failed. Please fix the following warnings and import again
Row #
What's Wrong?
NA
We’re having trouble to import template because of an error with our servers.
Replies (9)
Message 2 of 10
Shirin.arnold
Hi @s.odwyer,
Can you send me the template? Are you trying to import from Field Management or from BIM 360 Field?
If from BIM 360 Field, ensure to export from the admin checklist template library.
Shirin Arnold
Sr Product Line Manager
Message 3 of 10
s.odwyer
HI Shirin,
 I am using the next gen template and uploading that file.
Message 4 of 10
Shirin.arnold
Hi @s.odwyer,
Thanks, let me look into this file and see what is happening.
Kind regards,
Shirin Arnold
Message 5 of 10
Shirin.arnold
Hi @s.odwyer,
I just tested the file and it works for me. Can you try it again?
Shirin Arnold
Message 6 of 10
Shirin.arnold
Hi @s.odwyer,
I found the issue. The "response type" for section is mislabeled. If you look at the header where we have the definitions, we require "Section" not "Group Header" in column F. Make this change and the import will work.
Shirin Arnold
Message 7 of 10
anil_mistry
Autodesk Support
Autodesk Support
Hi @s.odwyer,
I'm just checking in to see if you need more help with this. Did the suggestion that @Shirin.arnold provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
Message 8 of 10
Jonathan.SuttonBZHKG
Community Visitor
Community Visitor
@Shirin.arnold @anil_mistry , I am getting the same error as mentioned here but the solutions provided don.t seem to resolve the issue I have. I have attached the file I'm trying to import.
Message 9 of 10
s.odwyer
Before I look at the file. Can you select all empty cells below the template and delete them.
It sometimes works for me.
Message 10 of 10
Community Visitor
Community Visitor
Hi Sean,
   Thanks for the quick reply and appreciate the help. I have selected a number of blank rows (well over 100) below the checklist questions and deleted them but it still fails to upload. I am conscious there is alot of text in some of the 'item text' cells and it is quick a large checklist with around 10 sections and at least 10 questions per section. Not sure if these could be causing the issue.
