Show where element come from - Links
Message 1 of 8
Hi there,
I hope you are well.
When we have a federate model in a complex project we may end up with hundred of model.
Is it anyway in BIM360 when you select an element to know where this element come from? As far as I can see, it does not appear in properties either in the tree.
Replies (7)
Message 2 of 8
Luciane_Conceicao
Autodesk Support
Autodesk Support
Thanks for your question.
I am not sure which file type you are working with and where you are saving the files, but I performed a quick test with DWG Xrefs.
I placed a parent DWG and its XREF in the Project Folders. When I selected an XREF object, it showed me the file name in Saved Path (Properties panel):
Is this your case?
Does it work the same way for you?
Cheers,
Luciane
Luciane Conceição Taylor
Product Support Specialist
Please click the button "Accept Solution" if this suggestion resolves your issue.
Message 3 of 8
Luciane_Conceicao
Autodesk Support
Autodesk Support
I wanted to check with you if you need further assistance with this matter.
Cheers,
Luciane
Message 4 of 8
Hi Luciane,
It is not my case in with Revit files, please see picture:
No reference to of where this element come from.No reference to of where this element come from.
Message 5 of 8
Luciane_Conceicao
Autodesk Support
Autodesk Support
Sorry for the delay.
I have the same results as you and am checking if there is a way to identify where the element comes from.
Cheers,
Luciane
Message 6 of 8
Thank you very much.
Message 7 of 8
Luciane_Conceicao
Autodesk Support
Autodesk Support
Hi Ambrosio,
I have added this idea on your behalf as I was not able to find a way to show the source of the Revit element.
Please vote it up.
Cheers,
Luciane
Message 8 of 8
markus_briglmeir
Hey @Anonymous,
Thanks for reaching out.
To understand your requirement and workflow better, could you talk a bit about how a project is structured so that it ends up with hundreds of models?
Thanks in advance,
Markus
Markus Briglmeir, Product Manager BIM 360 Design Collaboration
